EnthusiastMan »
https://forums.nicoclub.com/enthusiastman-u60438.html
Sat Mar 24, 2007 7:37 am
Hey guys, I've got a very confusing problem here and was wondering if you could help me out.
As the title states, I've got an S13 with a S14 SR20DET in it. Everything is swaped and wired in but I'm having a problem with the fuel pump coming on. At the fuel pump relay there is a black/pink wire that is supposed to be grounded to kick the fuel pump on. When I ground this wire out manually it kicks the fuel pump on. I've traced this back into the ECU harness and have found that it changes from a black/pink to a black/yellow wire and run to the ECU. When I hook my voltmeter to the black/yellow wire at the ECU and turn the key on, I get battery voltage. When I ground this wire out it kicks the fuel pump on. I know this is the way it's supposed to work but when I ground the wire out the fuel pump keeps running and doesn't stop. Normally they are suppose to run for 3-5 secs and then shut off. Also, if the ECU is providing battery voltage to this wire, what is supposed to ground it? I thought that the ECU would ground it because it's only supposed to be grounded for 3-5secs. This is very confusing.
