180fan wrote:something tells me you might want to check the fuse again. It could have blown again during the power-up. If it did, you've got a grounding issue, the juice is grounding out somewhere in your fuel system's wiring.
i checked the fuse again and its still good, its about to drive me crazy...it ran before it sat up for years and i dont know how the fuel pump could have went bad from just sitting.....Also thanx for replying to me since i got this 240 i got on two other forums and nobody replies to my posts other forums are also not set up as good as this one...guess i found a home...
