89 s13 KA24E wiring help
bamracing
Car: 1989 240SX Coupe dirt track race car / 1989 240SX Fastback parts car
The car will be track only, totally gutted. I want only the wires that make it go. I was thinking about starting at the ECU and keeping only wires that eventually feed into it. Then, if there was anything else that I had to have running, I could wire it directly to 12volt power. Will that work? What do I have to keep and what can I get rid of?
NissanSupraGTR
Car: 1990 240sx SE hatchback
if you're going to gut it, then ur going to remove anything you dont need right? Whats the point in messing with the wires? if you disconnect/remove the component, no power will be sent to that component...
bamracing
I'm more concerned with weight than electrical power. I'd love to be as far below 1900 lbs as possible. I also want to have as few wires as possible so that it will be easier to track down electrical problems as they arise.
