89 red top swapped 240sx that will not fire
DLYNNW
Car: 89 nissan S13.5 97 Kouki s14 06 toyota Bb
i got a 89 hatch with a red top sr20 and we wired it up with the diagram for the inside and outside harness from heavy throttle and it fired up fine. few days later it started and bucked and rattled and now it will not start. so we checked the fuel pump fuse and it was good all wires are connected fine and still nothing so we checked the computer for burnt tracks and it checked out ok. but the car is still getting no power to the fuel pump harness in the rear hatch when the key is turned. if anyone can help plz let me know wht u think. its got a 255 fuel pump and it checked out fine to. we tested it on another 240sx. were going to test the 2 egi relays this weekend see if there bad.
silverarrow27
Check ecu and your wiring again for the gray & brown plug by the battery.
DLYNNW
silverarrow27 wrote:Check ecu and your wiring again for the gray & brown plug by the battery.
u talking about the neutral safety switch we jumped it because it was auto and its now manual. i got wire connectors on all the wires so I'm going to go back through and redo them and soldier them for a better connection. but yeah it acts like it did before we jumped the safety it just cranks and nothing so im going to try it hope for the best.
silverarrow27
No I wasn't talking about the neutral safety plug below the fuse box. I was referring to the brown & gray plugs beside the battery. May be loose wires.
DLYNNW
ok i see wht your taling about im going to check it out tonite
DLYNNW
ok the plugs are tight and the wires have been sodered and still nothing
Veracity_Automotive
Car: S14 zenki
Well first try to narrow it down to what system is not functioning. Start by treating this as any other no start condition and check for the basics.
Does the car crank over? If no, locate the fault in the starter circuit.
If yes, it isn't the strater circuit so check and:A) - Verify you're getting spark. If no, find the ignition system fault.B) - Verify you're getting injector pulse and proper fuel pressure. If no, fin d the fuel system fault.
Approach it like this and it will help out a lot.
If you need in depth help let me know what your findings are and I'll help more.
DLYNNW
Veracity_Automotive wrote:Well first try to narrow it down to what system is not functioning. Start by treating this as any other no start condition and check for the basics.
the fuel pump has no power in the plug in the rear hatch but has power under the hood in the fuse on both sides. it cranks but will not start because the fuel pump is not getting power or coming on. thanks for helping
silverarrow27
So basically you're not getting fuel. Should check your wiring again since it's a new pump correct?
DLYNNW
wiring was all resodiered the other night because i thought it was a bad connection in the harness but it still is not getting power(aka fuel)to the fuel pump wiring in the hatch.
DLYNNW
ok fig out the prob ecu was not getting power it was not lighting up so i checked the harness in the motor bay and it was the neutral saftey or the 3wire for main ignition to the one. one of the 2 but the ecu is getting power now!!! now for the vaccums if anyone know plz let me know,im not using the cannister so wht run from the throttle body to wht
