Mine did the same thing, tore it apart (there's no way to get into it without destroying the casing) and sure enough, one of the contacts on the board was all scorched. I bought a new (used) one and popped it in, worked for a week and now it's the same story as the old one. Now i'm wondering if these things just break a lot or if the motor is shorting out and causing too much power to go through the relay.....holycrapitsJR wrote:ugh, same thing happen in my car, hot in FL too. I bought a "working" amp off ebay and it still clicks. drivers side no worky. pass. side okie dokie. if I wiggle the amp it works sometimes, sounds like a short inside the amp mebbe? anyone ever try to take one apart?
Just tore my 2nd dead relay apart and found that the same contact on this one is burnt out as on the last one. I looked at the wiring diagram to see how much resistance the power window motor is supposed to have but I couldn't find it. Anybody happen to know? Otherwise I'm gong to test the passenger side with my ohm meter and compare that to the driver side...I couldn't imagine that it would be anything else though. As far as your problem goes, you should check to see if you're getting power from the harness to the relay.kuroneko wrote:and yet another situation.same thing
passenger works, other doesn't. has the clicking.I tried switching the motor with one that i knew worked. NOTHING
I tried using the amp off of my buddy's car (both windows work on his) and NOTHING.
So i'm not really sure what the problem is. maybe there is a short somewhere in my wiring.
It's behind the door panel, just follow the bundle of wires that comes from the switch and it will lead you to a white rectangular box.Ladreik wrote:I need help with my power window assy, Passenger side went down but not up I could not find much info on diagrams and such but i am getting voltage to the switch. I did find one forum post of the power window Amp (or encoder) So i decided to search for it to test it... problem is I cant find it. From what I read it is connected with 2 screws but where is it located.
