89 Nissan 240 - problem
Brandon1605
Car: 1989 Nissan 240sx (S13)
Ok, so on my way home tonight, I was getting into it like I usually do on my road. Everything runs fine and seems to work fine until I hit about 4500 rpms. Then it seems to lose all power. It almost feels like when you hit a car's governor. If I try to accelerate any, it wont do a thing... it just keeps slowing down/bogging down. If I clutch in and out, it goes back to normal until I hit that RPM again. Im thinking its an ignition problem, but I wanted to see if anyone else has had this issue or experience with this issue.
Brandon1605
Bump, need some help please.
Gcustoms
Car: 1992 240sx LE
yeah that sounds like an ignition issue... uhm check the spark plugs, wires, and the rotor for rust, corrosion, or any damage. other than that idk
