89 KA24E sat in garage for a year, wont start
pabuchok
Car: 1989 240sx KA24E
2008 300C 5.7L
Project car has been sitting for over a year in the garage. It ran when it went in.
Tried starting it today and it turns over but will not fire up. Seems to be getting fuel since I can smell it from the exhaust but no spark. All the ignition seems to be connected, installed new cap and wires.
I do have a volt meter. Can I check the distributor and coil without messing up the engine?
TIA
nissan2.4
Car: 91 240SX hatch N/A KA
brian crower stage 2 cams
obx headers
custom cold air intake
removed cat, egr valve, anti swirl valves
Sounds to me like ur coil might be bad because if ur distributor was bad obviuosly u wouldnt have injector pulse so engine wouldnt be getting any gas, try taking ur voltmeter and check for voltage at the coil, if u have power then it could be the coil or ignitor, unfortunately there is no official way to check either one.
