'89 KA wiring help
bamracing
Car: 1989 240SX Coupe dirt track race car / 1989 240SX Fastback parts car
I'm trimming as much fat as I can from my wiring harness and just want to double check before I do the cutting. It's a stock 24E to be used for circle track racing only. Obviously, I don't need the horn, the air con, or the headlight relays, but what about the others? These relays are located in a small black box in the left front corner of the engine compartment. Thanks in advance for any help.
180fan
Car: 89 fastback
if you're going with fixed headlights, all you'd really need would be that ACC relay.
bamracing
Thanks for the info. Actually, I'll be going with no headlights so I guess the whole thing can go - including all the wiring in and out.
