SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Thu Feb 22, 2007 12:37 am
You can remover the steering column bezel, then you could remove the ignition cylinder by cutting two straight slots onto the bolts holding the cylinder on the steering column. Then use a flathead to unscrew the bolts. You might as well do this since you will have to do it to change the cylinder anyway.
Once it is off you can use a small phillips head and remove the ignition switch off the back of the cylinder and use a flathead or key to turn the switch. Turn it clockwise (not too far) and the car will start.
