seang »
https://forums.nicoclub.com/seang-u122444.html
Mon Aug 24, 2009 12:42 pm
I'm pretty darn sure the bellhousings are the same between your naps-z and the ka engine. Its good you have the oil pan figured out ahead of time. IDK about the motor mounts. Heres what I know about the trannys. The later HB's have fs5w71c trannys, while the earlier ones have another model, I forgot which one but the haynes manual specifies it. The fs5w71c's ratios are different between the 2wd and 4wd models. the 4wd has a 3.9? first gear ratio, and the 2wd has something like a 3.23 1st gear. Ratios for the other gears are also somewhat different between the two. I think the 240sx also uses the fs5w71c, but I'm not the freaking 240sx guru, so IDK about those ones.
