canucklehead »
https://forums.nicoclub.com/canucklehead-u105683.html
Thu Sep 11, 2008 6:48 am
I just bought a '94 Maxima. The right front power window wasn't working. I could hear the motor so I was pretty sure it was the window regulator. To take it apart, the door panel has several body panel plugs and there are some hidden screws. This should lift off easily, so don't force the panel or you'll break it. If it's not coming off, you probably haven't removed a couple of the covers on the door that expose other fasteners. there are several around the door handle and power window control.
Sure enuf, the regulator was buggered. The cables were intact, but they had become crossed over on the spool. Also, the upper cable had pulled out, but was not broken. It looked too hard to try to repair the cables, plus they had some kinks.
I looked on ebay and you can get complete assemblies with motor for $40-50. You can also get regulators as cheap as $11. We repaired this same problem in my father in law's GM truck in the fall/winter. We bought a jobber part and it stopped working last week!! A light bulb went off in my head and I decided I wanted to buy a quality part. I was worried that if someone is selling the PW motor &/or regulator that cheap, they must be of suspect quality. I noticed the warranty was 60 days!! I don't want to re-do this job again for a LONG TIME! So i did some more checking and ended up buying from The Car Part Warehouse. They have a 3 year warranty and claim their parts meet ISO9001 standards, etc..
The wierd thing is they show 2 types of regulators; one is "japanese style" ($23), the other is regular style, and it's $43. Despite their company policy referring to their staff as experts, nobody seemed to have any idea what the difference was. So i ordered both and they will arrive on monday. I will let all know which one works. I'm hoping I don't have to find out about their 3 year warranty.
I found it easier to gently lower the glass, disconnect the 2 bolts holding the glass to the regulator, then pull the glass out and get it out of the way. That way you don't have to worry about it crashing down on your hands, or smashing. it comes out very easily once disconnected.
hope this helps someone.
