89-94 coupe rear wide fenders
92 Convertible SE
I am looking for some wider rear fenders.. I saw a pair for sale on Ebay, but i dont do Ebay... I found the wider rear fender kit for the fastback, but im having a hard time locating it for the coupe... (not fender flares, but the actual rear corner panel...) if anyone has seen it, or knows where I can order it... please respond... thanx
karay240
Give underground motorsports a call. . . 1-888-UM-SPORTS they should have 'em.
nightstepper
Car: my girlfriend, my project car, and partying
Jspec has some, check them out.
underground
Car: 98 RB26DET 240SX
http://www.importfan.com/serie...=1256
also, http://www.chargespeed.com has them.
I would recommend importfan.com just because I have personally seen their rear widebody fenders and they fit quite well.
Some of their products have fitment issues, but this particular product is really good for the money...
ChrisUnderground
NiSmo240luvR
what is required in swappin out the rear fenders? is it as easy as the front? my back left one is real bad so if its not that hard id rather get 2 new ones......
underground
The fiberglass fenders can be either molded or riveted on. The carbon fiber fenders need to be riveted on.
McKinney, for the D1, simply screws his in. He knows ahead of time they are probably going to break. I don't recommend screwing them in however!
ChrisUnderground
NiSmo240luvR
but what about regular metal fenders? are they the same? they can be pulled off and new ones put on? for some reason people have told me that the back fenders cant just come off like the front fenders....????....
karay240
yea, the only car (import) that I can think of that you can replace all of the body panels are the miata. Doubt that they have anything for the 240 hatch. I know there's nothing out like that for the coupe (the rear fenders are attached to the roof)Whenever you put the wide body fenders on, you have to cut a portion of the rear fender off so that the rear tire doesn't get cut in half by it. if you want more info on wide body stuff, HCI just had a how-to article on the 350Z (march '04 issue). they went in depth enough to show you what goes on w/ something like that.
