89-93 SR20DET HOT START problem FIX!
Xenos911
Car: sil80
sorry for the caps, i am sooo excited.. this problem has been bothering me for soooo long, and I finally diagnosed teh problem!!! the hot start problem which i searched and i searched for for hours and hours and hours! It is funny because I am not even a mechanic. Ok ready... here it goes... it is the injectors... wanna know how to test it? let ur car warm up and try to crank it over... when it doesn't crank over take the wire harnesses outta ALL the injectors. Start it up. It should crank over no problem and run for like 2 seconds. VWALAHHH. then u know its ur injectors leaking. When you plug them all in again after this 2 second run-stall, it should start up again no problem. Don't worry too much, they are very easy to install new (or if ur like me used but upgraded) ones. You can test out which injector it is by process of elimination; hook them up, let it warm up, try to crank it over, if it won't start, take off only the first injector, still wont start, second, etc until it starts and you solved your problem and you replace all or the one injector depending on how cheap you are.
If this has helped you please pm me
