lbrowne »
https://forums.nicoclub.com/lbrowne-u3597.html
Sat Jan 12, 2008 8:35 pm
The write up I have is for 91+ which is as follows:
1. Cut and strip the cruise control switch wires.2. Cut and strip only the Green/Orange and Green/Yellow harness wires (leave the Green/White wire connected - the horn needs it!)3. Connect the White switch wire to the Green/Orange harness wire4. Connect the Green switch wire to the Green/Yellow harness wire5. Tap the Green/White harness wire and connect it to the yellow switch wire.
However, on the harness side the white/green-orange-yellow wires are there. However on an 89-90 the wires coming from the button are red blue and yellow. I'm thinking yellow is the same, but which is which for the red and blue?
thanks,
lbrowne
