89-90 clutch slave different from 91-94 - what to use for my '90 with SR20DET?
junk240sx
I was looking into getting a new slave cylinder since they're cheap and mine's old. Clutch has always been a little off. I'm wondering if it's because I'm using the SOHC slave cylinder?
Being that the 91-94 KA's are DOHC and Nissan has a different slave cylinder for the cars, I'm thinking for my DOHC SR20DET, I should get the 91-94 slave cylinder for my '90? What do you guys think?
robbbby
Just get one from a 91-94 for your SR's transmission. They're both the same anyways (sohc/dohc) it doesn't matter.
tazjig
Car: 1990 240sx (SR20)
Yes you should get one from a 91-94 because the sohc is different, i had a problem with that, the sohc is cylinder is a little longer.
