89 300ZX optical sensor Vs
A home for 1983–1989 300ZX owners!
Car guy here
Car: Restored B12s
Anyone with an 89 300ZX know what the Vs are for the dizzy's optical sensor:
on the 1' signal?
And on the 120' signal?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
they are both 5v
Car guy here
Car: Restored B12s
@evildky, Thanks! A professional with a high-end scanner (snap-on I think??) walked through the menus for me (no access to a 300ZX) and the scanner said battery V. Didn't think that was correct.
evildky
06 Nissan 350Z GT
The optic's are made by mitsubishi and are all basically the same, VG, L28ET, KA, CA, SR, RB, different trigger wheels and different housings but the same optic's and same signals.
Car guy here
Car: Restored B12s
@evildky, That is OUTSTANDING information!
Had looked at (at least) a dozen cars (in the junkyards) (completely disassembling each dizzy and checking and testing), including non-Nissans (various Subarus, Mercurys, et al - the other makes that used the same optical modules), trying to sort it out. You summed it in 1 sentence! What you said so well is exactly what my research showed. I would note, though, that in a couple of instances there "were" different Vs: while most were 5Vs, Nissan's E16i SM states 2.0-2.7 Vs for the 1', and Nissan's GA16i SM states 2.3-2.7 for the 1'. Thus, why I wanted to know if the 300ZXs and other Nissans (i.e., their ECUs) used the same or possibly other/different Vs.
Do you happen to know or can you confirm the 93 Quest Vs (1' and 120')?
And what about the '92 Pathfinder Vs?
Incidentally, the same high end professional shop scanner that showed the 300ZXs Vs to be battery V "did" correctly show 95 HB pickup I-4 Vs at 5 (5-0 and 0-5, 180' and 1', respectively).
Finally, do you know WHY they changed from 3-diode-pairing optical modules down to 2-diode-pairing modules? Like from RSB-03 to RSB-06 and RSB-07?
And, are RSB-07's fully interchangeable for RSB-06's - with the exact same signal results "expected" by the RSB-06 ECUs?
And, are 2-diode-pairing RSB-07's fully interchangeable for 3-diode-pairing RSB-03's - with the exact same signal results "expected" by the RSB-03 ECUs?
And, would 3-diode-pairing modules fully interchange where 2-diode-pairing modules were used - with the same signal results "expected" by the ECUs??
Thanks!
Return to “300ZX (Z31) Forum”
