steeda763 »
https://forums.nicoclub.com/steeda763-u44310.html
Wed Feb 18, 2009 8:02 am
I had the same symptoms several times.
Check to see if your plugs are fouling with oil. If they're not dry and white/tan in color, you should replace them. It's also a good idea to replace the spark plug wires and distributor cap if it's been a while, or you have no idea when they were replaced.
Fuel filter is a possibility. Fuel pumps usually die completely...they won't go in and out (unless you're having another electrical issue).
If it's missing, I almost guarantee it's the three items that I listed in the ignition. Luckily, they're all reasonably inexpensive to try out.
