89 240sx won't start
1989240sx
Car: 1989 240sx and 1974 duster
so my car is giving me trouble again i start this the first time of the day and it stared just fine after that it has not start right it want to stay at 500 rpm when it should be around 700rpm do you guy have any ideas what would be wrong?when i can get it to stay alive it sound like it is miss firing./ also the only way i can get it going to to rev it up but than it go down back to 500 rpmit work fine yesterday
kys
Car: 1992 Nissan 240sx
I had a problem similar to that. I suggest checking your injectors. Could be loose injector just not getting enough fuel in, or clogged injector. if it's not injectors then it might be something bigger like compression in the cylinders? Maybe even something as simple as your spark plugs.
MCCIRE
Car: 1990 Nissan 240sx
Ah this old problem. Same here. I agree with the other guy, start with the plugs,wires,cap,timing and CORRECT firing order. Check those sparks! You would'nt believe the trouble I had with the order. Then again I just started working on this car. Also, there is a way to check compression through the plug holes and its on here, just search it. I also ended up cleaning my MAF and replacing the TPS (throttle position sensor). I know this sounds kinda silly but check your exhaust, mainly your cat. Mine glowed bright red while I had this prob and eventually I hollowed it out because it was clogged to hell. Or you can replace it. I was just broke at the time hehe. After all that it runs great. How many miles you got on it anyway?
