gumby74 »
https://forums.nicoclub.com/gumby74-u53716.html
Sat Mar 29, 2008 1:04 pm
Refer to the original steering wheel for the positioning of the dowel pins.There is a write-up on the cruise control relocation somewhere on here. I think in the convertible section.The "top" arrow or marking will not be at exactly 12 o'clock. If you had the steering wheel centered before removal, there is a small punchmark at the base of the splined shaft. Use a sharpie to make a mark on the very end of the steering shaft. That way you will know how to offset the new steering wheel so it is perfectly straight.Sounds kinda' confusing, just do one thing at a time. You'll be alright.
