Dante »
https://forums.nicoclub.com/dante-u8113.html
Sat Jul 17, 2004 10:49 am
Update: Tested injector pulse, all injectors pulsed about the same, a fairly quick series of flashes. They seem fine. While I was at it I ran a compression test, all cylinders except #2 were 145-150 psi, and #2 was 50-60 psi. I put about a teaspoon of oil in the cylinder and pressures jumped up to where they should've been. This indicates a bad ring seating, but I don't think that one bad cylinder would be enough to keep it from starting.
I didn't check fuel pressure as I wanted to check everything else before spending $35 on a gauge, but I can hear the pump come on when I turn the key, and before I did the timing job everything worked great. I also rechecked the firing order, even tried doing it a few other ways, and I'm convinced I had it correctly the first time. I checked spark, all cylinders are firing.
The car sounds just as it should, only it doesn't catch. Tonight the car briefly started to sputter (hope sprang eternal), but only once and nothing after that. I have a feeling that it is either something really simple or really bad. Can you think of anything very dumb I may be missing here? If nothing comes up, I'll go get the fuel pressure tester tomorrow and try that.
Big Red: What type of manual was this? I am using a Chilton.
