180fan »
https://forums.nicoclub.com/180fan-u3602.html
Sun Mar 19, 2006 9:53 pm
pull the valve cover and take a gander down the front where the chain goes. If you see alot of slack on the chain, and if you can move the guide around with a screw driver, chances are you're in for it as the chain probably ate through the front cover and went to the cooling passages.
