NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Sat Jul 26, 2003 5:44 am
if its a manual trans try tapping on the start relay(blue relay with 2 connectors ,one big one small) while someone is holding the key in the start position. if it starts replace the relay. if its an auto trns try wiggling the shifter while holging the key in the start position. if it starts adjust the park/neutral switch or shift lever. if it still dont start bydoing the above check to see if your ign wire directly above the panel below your steering coloum has been cut and an after market alarm or ign cut is wired in. if so take a large paper clip and shove it into the but connectors for each side of the splice and try to start it. if it starts remove the alarm or ign kill device. and reconnect the ign wire together.
