I was worried this might happen. As you can see from the pictures, only two of the speaker's mounting holes line up with the adapter. I've tried every position possible and even considered drilling additional holes, but the diameter of the adapter's hole is just too big to even add one more screw on the bottom half.
My question is if the speakers should be fine without having screws on the bottom half? Will the door panel hold the speaker in place to prevent it from "flapping" against the adapter?
Thanks!
