My problem is when I turn the car on it sputters/mis fires I guess you can call it.I hit the gas and for .1 second it sounds like as if one injector or plug was unhooked then revvs.When I drive, going into first gear it sputters then goes back to normal. If I floor it it'll get up and sputter ridiculously at the same time.
Reading the other threads they all said to change injectors and MAF. If I unplug my MAF the car just dies. I have swapped the injectors like 3 times already and problem continues. I have gone through 3 IAC and problem still remains. I have swapped the TPS twice and problem still remains. I even tested my MAF with my cousin's and still problem remains. When I replaced my plugs they came out with the tip a bit white as to the cylinders probably running too hott. My wires are brand new as well and the cap and rotor are semi new. I replaced fuel filter yesterday back to the 240 original one instead of a 300zx one. My FP seems to function correctly but who knows how old it is, but it has been replaced before.
I was thinking maybe I should double check my timing again and make sure it's correct perhaps.
As for my idling, let's just say it's a headache.
I can't seem to find any vacuum leaks since I only got like 3 or 4 since I removed my emissions. IDk if it can be a wire but if anybody here can really help me out that would be great. Engine has like maybe 1-2k miles on it since rebuild and it sucks because I was hoping it would be good and running fine for once but in reality runs worse then my last engine I screwed up.
Just incase you need to know my modifications here's a list:
-Injen Intake
-4-2-1 Header
-Emission removal
-3inch test pipe
-3inch cat back
Thats all that I know regarding anything with the motor and I still have my SCV installed just hooked up to a vacuum line which opens as I give throttle.Thanks for reading I hope this all makes sense your help is very much needed.
