Altiman94 wrote:lifters.
That must have been it - it coincides w/ the symptons/possibilities from other threads.
I'll have to remove those timing chain tensioners/guides/whatnot one of these days, but not yet, haha.
Anyway, something must have been gunked or something affecting the oil pickup because I was full on oil and it was tapping. The odd thing was that sometimes when I turn off the car (after it taps) I check the oil level & it says "ZERO" - picks up no hint of oil. I start the car, check the oil, and it's chock full.
I decided that since I was due for an oil change anyway, I put in 10w30 for a slightly thicker mix opposed to my normal 5w40.
Problem went away... for tonight... go figure. As a side note, this started happening after I left the car on jack stands for 1 week fixing brakes. Hopefully that's all it was?
Do you think my oil pick up is bad? how do I replace that if it is?
THANKS
