89 240sx se sr20det Replaced TOB, now running rich
terrible01
Car: 1989 240sx se hatch w/sr20det
This past weekend I replace my throw out bearing and slave cylinder. removed the useless clutch damper box too. While installing the transmission some of the sensor wiring on the transmission came off, so i wired them back up not knowing what wire goes where. Im sure the connectors are correct, just not the wiring to the sensor from the connector... since then the car idles higher with a richer a/f @ 11.0 to 13.0 where it used to be 14.0 to 17.0.
Im running a sr20det w/ 5spd transmission. three sensors on the side. i've tried looking for the appropriate wiring diagram, but cant seem to find the wire color coding in the fsm.
any help would be great, thanks...
terrible01
just a thought, but could someone else look at their 5spd sr20 and pass the wire color coding along?
