89 240SX/S14 DIFF PROBLEMS. PLEASE HELP
BRADYNS240SX
Car: 1989 240SX SR20 SWAP
I am going crazy, I cant get the short shaft all the way in the pumpkin with the new diff installed. Also I have got to get some shims but unsure where to get the correct shims to fix the pinion gear back lash..There is too much play....Anyone ever actually done this?Let me explain in a little more detail what I have going on.
I have an 89 240sx with 6 bolt half shafts. I purchased a VLSD off of e-bay that came as the diff and the 6 bolt half shafts. NO PUMPKIN.So what I had to do is take my Diff out of my car, pull the cover off,take the half shafts out, remove the ring gear from my original pumpkin, install it on new diff. Then reasemble the diff, Took my new 6 bolt shafts that came with the new diff. and install. got the longer shaft in no problem the shorter shaft stops about 1/4 inch short. Will not go all the way in like originals did. What is up with that? Also need the shims for the ring gear. Seems to be way too much play...
Any help would be great. I may have to end up taking my diff to a nissan mechanic to get this right.
Modified by BRADYNS240SX at 6:20 PM 5/13/2007
