BlackHat »
https://forums.nicoclub.com/blackhat-u38398.html
Thu Mar 30, 2006 3:13 am
I thought that I had a pretty good idea going for a setup. Posting here in case it gives someone else an idea. It's not done, but I'll post the pics as I get farther into the project.
View of the supports from the front. I'm probably going to add two more supports along the sides.
Yeah Yeah, I know. It's not the straightest, but it does its job and I managed to miss the brake lines that run on the underside.
I have the top cut out for 2 8" subs and 2 4"x6" speakers that would normally go on the back brackets of the hatchback. The Subs are going to be in sealed boxes and they just barely fit sideways.
View from the back. The top will have hinges attached in the middle for easy access to anything in the cabinet.
View of just the top cut out.
I'll post more as I get farther along. I have everything lined out, just trying to get it all put together.
Also, if anyone has a link or can post information about the factor harness layout I sure would appreciate it. I need to know which wires are what so I can splice into them. I already have a harness so I don't mess up the factory one, but have no clue where to find the wire layout.
