formalyDSM wrote:IT IS ALIVE!!! it runs, idles, and gosto redline. now the only problem is low idle. it's about 450rpm how do i change it to 750rpms
Tell us how you fixed your original problem.
Here's how to adjust the idle speed:To adjust the IAA, Fully warm up the motor. Shut motor off. Disconnect the TPS harness connector. Start motor. Check the idle speed. It should read 650 RPM; If not, adjust the idle screw until you get 650 RPM. The idle screw is located on the passenger's side of the motor near the firewall below the intake manifold. Stop the motor. Reconnect the TPS harness connector. Start motor. The idle speed should now be 700 RPM.
