NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Wed Oct 26, 2005 3:42 am
Mike I dont think dantech is with midway anymore.However you should be able to order that boot from anyone of our dealer sponsers. Go into their look up table.
As far as install on this boot goes. You remove the knob and the upper trim and body boots. Then you cut the old one where it wraps around the shaft and slide it off. The new one actuall slides offer the upper part of the shifter, it streches over it and then pops snug with the lower shaft once you clear the end of the upper part of the shifter. you dont even need to remove the shifter from the trans.
