180fan »
https://forums.nicoclub.com/180fan-u3602.html
Wed May 17, 2006 8:48 pm
Ha ha ha it's not that bad on the SOHC. At least you don't have to pull the oil pan like on the DOHC. Just pull the oil pump, dist, valve cover and the front cover. It all goes pretty fast, and the aligning of the rest of it when it all goes back is pretty easy also. Keyways on the crank and cam point up and make a D tipped \ on the oil pump and the dist in a similar direction \ but pointing downwards. It shouldn't even take a day to do. I think the fastest chain job I did on a SOHC was about 4 hours. You'll have little to no problems with the SOHC.
