goshoryuken »
https://forums.nicoclub.com/goshoryuken-u4208.html
Sun May 18, 2003 11:03 am
Hi. I have a 1989 240sx FB. I bought it from someone on ebay. The car had many problems with it, which have all been fixed, except one. Since I bought it, it has been at my mechanics shop. He can't figure out the problem so easily, and has tried a few things. This is what I can describe about the problem . . . You turn the car on, and it revs up to about 4,000 rpm, then drops and the whole car shakes like an earthquake for about 5 or 6 seconds, before it stalls. The car stalls each and every single time like this, but if you rev it up and give it some gas, it stabilizes, then if you take your foot off the pedal, things go back to normal . . it shakes and turns off. The spark plugs are good, the wires are good, the maf is good, the o2 sensor is good, the temperature sensor is good. My next two guesses are the timing needs work, and the vacuum sensors need to be looked at. Can anyone please help me with this!?????
Thanks in advance.-GoShoryuken
