89 240sx hesitaton (Look)
Jackask89nissan
I have a 89 240 sx that hesitates real bad @ every rpm and every gear. the car runs really bad below 2800 rpm. if you go WOT is dies completly out. need any sugestion to why its doing this. any. thx
dkdeleon68
Car: 1991 240
Check your MAF and fuel pump and fuel filter for starters
silvia2slow
Car: 1990 Nissan 240sx
i had a bad TPS on my car and it would hesitate at any rpm in any gear. it wouldn't die like you said it does but it wouldn't hurt to get a new TPS. or if you know someone with the ka24e swap put the TPS and see if it does anything.
rotorimp
Car: 02 Xterra, 60 IH Metro
Unplug the injectors one at a time--sounds like you have a bad one.
