89 240sx headlights go up but not down. help....
ga demon
Car: 1990 240sx
replaced the headlight switch and called myself checking the fuses. the lights will come up when you press the headlight switch and turn the lights on. if I manually turn them down they stay down. Any help will be appreciated.
Fenvy
Car: 2005 350Z Base 6MT
your headlight motor is dead
ricebike
2002 Quest
2005 Altima
oor, maybe, the button on the left of the steering wheel was pushed down, keeping your headlights in the "up" position.
i keep mine's depressed this past winter, so i don't worry about my headlights freezing shut when i need to drive
i've read that from another member who "DOH" it was that simple.
USDM240
Car: 1993 Nissan 240SX Limited Edition 'vert
which headlight switch did you replace? the one of the steering column, or the one on the cluster surround? if you havent replaced the one on the column, replace it. thats most likely your culprit.
