89 240sx hatch, Replaced injectors now I smell gas in the cabin..
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
And, I see small puddles (minor) on the intake manifold or something...
New injectors w new o rings.. I put vaseline on the o rings..
Any idea what could be up?
2kul
Car: 1990 S13
replace the o-rings again. go to a nissan dealer and get the original o-rings. dont use the autozone crap... this happened to me too
Acecool
I bought these O rings off of a website, and they appeared to look the same as the others... I guess Ill do a chargeback on the $12 I spent..
Thanks
Acecool
DeatschWerks is where I bought them...
Acecool
Ok, I purchased new Nissan dealership ones, they look the same..
Ill try spraying them with liquid silicone in about 3 hours when my car has cooled off.
Josh
steve_o1989
Car: '90 240sx coupe
If the new O-rings dont help, check to make sure that you injector seals (the ones right at the intake manifold) are good.
Acecool
2 injectors are leaking, which is my problem.. I am getting some today or tomorrow for $300 (set of 4, 550cc probably)
I might use some epoxy around the plastic part of the injector as a temporary fix...
