InsanityInc »
https://forums.nicoclub.com/insanityinc-u19073.html
Sat Jun 11, 2005 8:16 am
You should figure out what's actually wrong before you go changing things willy-nilly. For all you know, your camshaft could be out of phase. Mine were off one tooth on the cam chain (DOHC), and the compression was 150, but my cylinder leakage was 8%, so couldn't figure out what was wrong. Turned the cams one tooth forward and my compression went up to 190 across the board (I assume it went over stock compression due to my engine modifications).
