89 240sx gauge cluster problem???
cheo87
Car: 1989 240sx coupe
my meter fuse keeps on blown up right when i turn the key on and u could see the spark come in out when i put the fuse.can it be that my fuse box its mess up o and i also check the wire coming out of the fuse box its like a green color all the way behind the gauge cluster and it was good but i couldtn get farther i dont really want to take the whole dash did any one had this problem plxzzz someone help
kissmeimjwsh
Car: 1989 240sx 1992 240sx 1998 s10 lowrider
theres a short somewhere. in your fuse box u have a power wire and load wire. chances are its the load wire (one that doesnt have power when fuse is out and key is turned) follow that n see whats touching metal. or you could just put a jumper wire in and wait to see which wire melted (just kidding dont do that)
cheo87
yea i followed that wire and it was'nt touching any metal is just lead to a ground right behind the dash on top of the ecu does any body got anymore inputs and also my brake lights aren't working the bulbs are good the just wont bright up when i press on the brakes but the running lights work this is a nightmare i need help bad
