180fan »
https://forums.nicoclub.com/180fan-u3602.html
Mon Mar 01, 2004 10:01 am
Alrighty here we go again. This time, electrical.
1. It looks like every 6 or 7 months now, I go through one headlight bulb, more specifically the drivers side headlight bulb. The other thing I notice is that when I flip to high beams, the drivers side also takes a second or two to get into high beam. The one side blew out again last night. I started with the AC, stereo, and the blower going.
2. Along those same lines, when I flip the combo switch, sometimes the headlights dont flip up, but the bulbs to light up. When I hit the flip up/flip down button on my console, they flip up and then I can hit the button again to put that switch in the off position and keep my headlights in the up position. They flip back down as normal.
3. My turn signal lights stay on if I plug in the bulbs for the front turn signal lights. Right now my rears are ok. I've already tried replacing the flasher unit (expensive relay!) but that didn't work. I have also replaced the combination switch (the stick that controls the turn signals/lights) and that didn't work either.
When the turn signal is turned on with the exterior lights off, they stay on (for that side switched on with bulbs in).When the turn signal is turned on with the exterior lights on, they click once. However, when the exterior lights are on, the turn signals (all 4) stay on. On the instrument cluster, I'm seeing the left arrow glow more brightly than the right but they stay on.
4. The "brake" light stays on even though the ebrake is disengaged. I also notice at night, the battery light is dimly lighted too. When the car's warmed up, at around 2k rpm, the brake light will buzz and with the buzzing the light will buzz on and off very rapidly.
any ideas? I'm thinking maybe the harness at the front controlling the headlights and turn signals needs to be replaced. Any ideas if that'll fix my combination of problems? I also suspect a ground issue with the "brake" light in the cluster.
