U12 2NR »
https://forums.nicoclub.com/u12-2nr-u5979.html
Mon Jul 14, 2003 8:37 pm
The buzzing noise is from the starter (solonoid), it does that when the battery is low on juice, so that is normal.
So you're saying that if you have the car jump started, it'll run, but as soon as you shut it off, the battery is dead? You can't start it immediately or does it take a while to drain the battery?
If the battery is dead immediately, then you should check the connections on the positive terminal of the battery. There's the main big power wire, and two smaller connections running off it. One is for the starter, and the other is for the alternator. The alternator wire is what charges the battery. I sounds as though this wire isn't connected properly or damaged somehow. Which is causing the battery not to get charged and the car is just running off the alternator. With the car running, you should measure the voltage at the battery terminal using a multimeter.
