ImportDrftr. »
https://forums.nicoclub.com/importdrftr-u59272.html
Sat Apr 14, 2007 7:06 pm
Alright to make it straight to the point. I have two problems that im trying to fix.
1) Car wont start
2) I have multiple leaks (driver & pass window, taillight leak & possi windshield leak)
A. I've replaced the starter thinking it was the starter, but it wasnt. I've check fuses under the hood & driver side. Check everything at least possible.
Solution - Tapped into my ECU's orange wire straight to the solenoid clip. Had it running for a few days, then one day, again....not starting.
Problem - I can turn the key, but it does nothing. The engine doesnt turn or tries to start at all. Just nothing. Im runnin out of ideas. (and i get power)
B. I washed my car one day and noticed droplets on the car, but was in the inside. On both sides. When it rains, i get water in my spare tire well. Bought the car like that. Its comin through the tail lights.
Solution - I dont know what to do.
Figured i find a solution as many people are knowledgeable here.
Thanks a lot.
- ID.
