Toreva! »
https://forums.nicoclub.com/toreva-u43569.html
Mon Dec 11, 2006 9:51 pm
This is a quick fix but you will need to repaint your deck lid afterwards, I've done this process on a hatch, and a coupe deck lid what you will need is a ball peen hammer (hammer with a round end), some kitty hair (really fibrous fiberglass), resin, and hardener of course, and some bondo. Take the rack off of the deck lid and place the ball peen hammer (round side into the hole) then take another hammer and hit the flat end of the ball peen to make a SMALL dent inside of the hole. If you hit to hard you will make creases, if you don't hit hard enough your dent will be to small to fill in smooth. When you have hammered all the holes to about 3/4 or 3/8 of an inch in depth fiberglass all of the holes in making sure not to overfill them. Once everything is fiberglassed and dried. Bondo, and sand tell smooth. Pick up some spray paint and repaint the smooth, hole less deck lid maybe a couple wet sands and buffs and your done. (I would recommend doing this it builds skill and your car is white its extremely easy to match spray paint too.)
But, if you get lazy sometimes like I do, just pick up another deck lid for 30-40 bucks.
-Trevor
