NISTECH wrote:try it in forth gear. If it wants to move in forth I suspect your spun the key in your counter shaft gear. I have seen this a couple times on the trans in the truck around that same year. If it doesent move even then I would at least pull the trnas out to do a visual on the clutch components. Then tear down the trans for inspection if your dont find anything wrong at the clutch.
it has arround 200,000 miles fyi but engine is great, car is in great condition
looking at it today the clutch moves, and everything in the clutch system seems to be fine. broke it down to the shifter/transmission rails or the trany being broken about what you described. the car just wont go in to any gear at all, it wants to catch 1st and 4th some times, but pretty much none at all, now there were no trany problems at first, so the trany should be fine, but some where between the shifter and the trany could be fun, or inside the trany on more of the shifting section
problem comes when I need that car to be running by the end of this month
