wirelessalpha »
https://forums.nicoclub.com/wirelessalpha-u33700.html
Mon Apr 17, 2006 6:08 pm
The first and last time I did the same thing you did - was on my eg civic.
Solution: If you have any remaining material (which you should). Cut the f'ed up part into a measurable square section. Then, using the leftover material - cut out the same square. Then go back to the installed carpet, and right where the new "square hole" is, slide in some duct tape - with the sticky side up. Then place the newly cut sqare in there. Make sense?
Hope it works out for you.
