thienthan wrote:the two rear piston are ok ( i'm guessing) i did the brakes and they both went back in. i was driving around and when i got out i smell the my brakes and the two on the driver side smells more burnt then the passenger side.
Now that you replaced teh pads/rotors, is the car still stopping by itself?
Um, did you break in the pads/rotors? You need to get that layer of "crap" off w/ a break in procedure. Also, I hoped you covered the pads & rotors w/ brake/carb cleaner before you took it for a run to prevent it from glazing.
some procedures:
http://www.tirerack.com/brakes/tech/tec ... ?techid=85
Also, did you remember to bleed the brakes?
