BlackHat »
https://forums.nicoclub.com/blackhat-u38398.html
Thu Mar 16, 2006 10:12 am
I believe I'm having some trouble with dead motor mounts. When I got the car I could tell they were on their way out (the motor vibrates quite a bit). Lately the entire drivetrain has been shaking bad when in low rpm 1st and 2nd gear. I'm pretty sure this is the motor mounts, but just in case this sounds familiar to someone else I'll add a couple other details.
I just replaced the clutch with a mild performance clutch which I thought could be causing more stress on the motor mounts (old clutch was slipping). I also inadvertantly snapped the decaying plastic connection on the AIV, which I just recently found out shouldn't be that big of a deal anyway. But I had heard it can mess with idling, so I thought I'd mention it. Other than that I don't know of any other malfunctions with the car that could cause this.
Now, my question is, I have a kae that I'm rebuilding for Turbo applications but I'm probably about 4-5 months out before I'll finish it. The 240 is becoming very annoying to drive with the shuddering going on (not to mention I don't want to break anything because the engine is flailing around the engine compartment). Are there any reasons I wouldn't want to replace the motor mounts now and use them with the new engine when I get it done? Or is it something that I can't reuse when I get ready to swap engines?
