gumby74 »
https://forums.nicoclub.com/gumby74-u53716.html
Fri Nov 27, 2009 4:14 pm
I don't really see Altima wheels being any wider or higher in offset than stock 240sx wheels. Assuming you plan on running a stock tire size, I don't think you should have any clearance issues.
That being said, a spacer of any thickness greater than 5mm will require longer studs. And even 5mm is being generous.
