180fan »
https://forums.nicoclub.com/180fan-u3602.html
Sun Feb 29, 2004 6:02 pm
Just replace that injector. They're not too bad if they're bought in singles. Most people here replace them from 30-50 per injector. The orings can be had for 5 bucks a set of 4. Replace them all while you're swapping the broken injector.
might want to make sure that the seals are on the injectors and then put the rail on top. Use a little bit of gas on the seals so that the rail will slide a bit on the seals of the injectors as you tighten down the rail to press it onto the injectors.
Look around for where the fluid is originating from. If you don't see any around the master, then look around the slave. There should be the hardline to a loop damper, to the rubber hose, to the slave. If you've got leakage around the rod that pushes on the fork, then yeah it's your slave. If it's anywhere else, replace accordingly. Now might actually be a good time to look into pulling out the damper loop. You can buy a stainless steel line from takamotorsports.com or you can just bend your hardline using a line bender and hook up the stock rubber one to the end of it.
The starter, you can ask around in the buy/sell/trade part of the forums. There are a couple people parting out. Actually I might have a starter lying around. Lemmie get back to you on that. Probably sell it pretty cheap too. Shipping is gonna be expensive though. If you're looking for used parts, there's always the junkyard. But if it's a starter, might wanna look into getting a reman since that'll probably last alot longer than just a used one.
The motor mounts, you'd probably be able to find some people selling on ebay. If you're looking for nismo, I'd check courtesyparts.com. They've got the nismo motor mounts cheaper than ebay. It does move the engine up though about an inch.
The high idle, you can adjust the idle by turning the screw located at the back of the intake manifold. There are plenty of posts about how to adjust that.
