89 240 sx KA24E stumbles/misses at 3100-3500 rpm
chifarmer
Car: 1989 240sx
I have searched through the forum but nothing really matches
Engine runs pretty well for 201k miles. Starts fine, idles fine accelerates fine till about 3100-3500 rpm and then intermittently stumbles or misses or seems like no fuel since doesn't backfire when catches.
Have replaced coil, plugs, wires, cap, rotor, TPS, engine temp sensor, O2 sensor. No codes on ECU, no check engine light. Injectors replaced about 50k ago before I got it. Cleaned MAF, electrical connectors, AIV mechanism, optical sensor in distributor (crank angle sensor). Only does it under load (i.e. can run it at rpm in neutral with no miss). All plugs seem to be firing.
THis is drivng me nuts. Any suggestions?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
THat kind of sounds MAF related to me......
Another240Bandwagoner
same thing happens to mine hate to bump and old post but i need my only car fixed soon thanks....
chifarmer
Car: 1989 240sx
Turns out it was the MAFS. Thanks Wes.
I picked up a used one on eBay for $13. Cleaned it up, popped it in and all is good.
I think rockauto.com has them rebuilt for about $90.
Good luck.
