180fan »
https://forums.nicoclub.com/180fan-u3602.html
Tue Feb 27, 2007 7:46 pm
it's probably the connector that's taken a crap on you. don't sweat it too much though, clean and tighten the female connectors on the plug to the harness and try again. if you've got the engine harness out too, you can also check for continuity to see if that's what's causing the problem.
