slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Mon Jun 26, 2006 12:29 pm
I presume you removed the stock AC fan? If so you've moved all of the active cooling to a single fan, and I have a feeling that 14" just isn't up to snuff. I'm not sure if anyone has ever actually measured it, but I'm pretty sure that clutch fan puts out way more than 1750cfm(roughly what that 14" is rated for). Also because your primary fan is now attached to the radiator, air isn't as free to enter the engine bay as it once way.
What type of climate are we talking about, and were you cruising, or sitting in traffic?
When's the last the radiator, fluid, thermostat, etc were changed? These things matter a great deal also.
'slip
